2016 R1200rt adjustable gear shift lever
Good to see you on Dennis.
I will add a bit to your title, I think it will help.
Good luck.
Gary
Check out one of the threads in the Similar Threads pane at the bottom of the screen.
I need a longer or adjustable gear shift lever foe my 2016 r1200 rt does anybody make one.? Dennis Shirley ds248rv4@gmail.com
Depends on what you mean. If you need a bigger toe-piece, that link is provided above. If you want to move the shift lever lower, in conjunction with lowered pegs, you can buy an extended-range turnbuckle.... But DON'T. Your OEM adjustment is enough that you can move the shifter as far as it will go, and still enable you to downshift. If you move the shifter any lower, then you lose authority to make downshifts. DAMHIK
Cap
