16064-1979
I changed all my oils today preparing for a fall trip. When I drained the final drive oil and went to take the fill plug out I couldnt get it to loosen. So I tried a little harder and guess what. The torx head stripped out on the fill plug. O crap. I'd already drained the oil. No way to get the plug out without some serious surgery.
Thought about it a while and decided to add the 180 ml oil thru the vent plug. 2010 and up have a vent on the final drive. Rigged up a small hose and put the oil in slowly thru the vent. I left the drain plug loose when I first started filling to see if the oil was getting down into the gears. It began dripping so I installed the plug and filled it up. I guess my question is anything wrong with doing this? Seemed to work. Also this winter I will have to do the repair. Any ideas how to get the fill plug out? If it was my old truck I'd weld a nut on it. Also do you think the plug was over torqed? At 24K it was serviced at the dealer. 29K now. Im a fairly good mechanic working on my own bikes doing general maint for my 50 years of riding. First time Ive stripped a torx out. The socket is fairly new and in good condition.. Any thoughts? Thanks.
