Dave_Faria
Slow & Easy
GM list. I'm approaching the wear limit for the front pads on my RT. The OEM pads for the front are $140. The brakes on the 2004 RT are ABS and integral. Has anyone tried an after market pad??? I'm also curious to know if I replace the front and rear pads with the same material(ceramic rather than sintered for example) will the brakes function as designed??? At $240 for both front and rear pads I need to find an alternative.
Thanks for your thoughts
