Not a cutaway view, but maybe try a mirror inside and a flashlight?
If they were exposed to fuel, they'd eventually corrode as the alloy metal reacts to the fuel.
No apologies necessary Good to read your "find". I am sure others could benefit from your experience. Thanks.Apologies for bumping a fairly dead thread a few months later, but assuming the tank is the same as on my 96 RS then they're not exposed to fuel. I cross threaded mine and the bolt was stuck fast, and in the process of trying to remove the bolt I ended up pulling the actual nut out as well.
I epoxied in a riv-nut as a "temporary" fix that I expected to do something about later, but it's been holding fast since, so I haven't given it much thought until I saw this post.
I received the bike with quite a few miles on it so I'm not sure whether the nuts I pulled out were OE or were a prior repair by an owner, but there was literally .. quite literally .. a round head capped nut that I pulled out with the cross threaded bolt. In either event, no fuel leak since, and my own "repair" is basically a straight-through open-ended nut that would have gushed gas by now
