Drove my sweet running 2003 R1150 RT (21k miles, single spark) into the shop, replaced a rusted out muffler. Used same 02 sensor. Tried to start er up, no joy. Kickstand switch works fine. Checked spark by grounding plugs against cylinder head, yes. Spark was really strong. The spark seemed to skip a beat occasionally. pulled injectors and checked Fuel injector spray pattern, good spray pattern while cranking over. Checked each fuse individually. Checked relays by swapping out the horn relay, all good. About 1 volt drop at the battery while cranking. Hooked up the GS911 and ran the HES test, fine. No fault codes stored. Checked pump by jumpering from battery, no prob. Pulled tank and dumped the gas, added 2 gallons of fresh, no good. Thinking the bike may have been immobilized by the HES test, I pulled the Motronic fuse, waited an hour, no start.
A few other observations: Strong smell of gas getting blown out exhaust. Starting hums and clunks sound normal. Probably 50 attempts to start, nada.
Could the dreaded HES problem be a possible culprit? This same no start problem happened about a month ago while I was doing a TBS, but after about 10 attempts she lit up. I had a gut feeling at the time that this issue was not resolved. The HES is about the only thing I havent really chased yet, thinking it was something more simple and straightforward.
Please Mr. Wizard, help!
