mrtnfischer
Der Kaptain
I have acquired a rebuilt R69s with 30 miles on it. Bad compression and it would run and smoke, took off the head and the cylinder to find the head gasket was new but was deteriorated or eaten away down to the oil drain hole from the Valve cover oil drain hole and gases from firing were going into the crankcase.
Hence, the lower compression for a new engine rebuild (60lbs). This engine was rebuilt in 2001 at BOB's BMWS. IN going over the bike, all of the nuts, bolts were loose, from the electrical to the center stand including the head bolts. Wow, if you ever get a engine rebuilt by someone else,,,, better check it out first. PS it is for sale..
Did this ever happen to anyone on a later airhead or is this indicative of a /2..
