hi , has anyone installed crash bar reinforcement on a 1250 gsa thanks, looking at touratech or altrider
I run these on my 2017.5 GS. I just loosen the two lower screws on each support and then take the OEM bars off, they drop right out.
These are the same as a 1250.
Yes there are two supports, one on each side. So these, not this, IMHO."These" ?
I used the tourathech because the alt rider uses the motor mount bolt. To take if the crash bars for service you must remove the rearcengine mount to get the reinforced crash bars off. Touratech leave the reinforce bar attached and pull off thr rubber mount, easy peezy.
"These" ?
Yes you may be correct.Maybe he meant "these" as in what brand are these? Was hard for me to see what brand they were from the instructions until the picture got blown up larger.
