I
im4xru
Was doing a little off-roading on the ÔÇÖ98 1100GS this past weekend with some friends where we did several water-crossings. About ?? mile after doing the one in the photo my engine went dead. On the roadside was able to determine I had no engine spark. After swapping around the fuses (#5 - motronic) and relays (motronic and fuel pump) and looking for obvious broken wires or water damage, I retrieved the trailer and hauled the bike to the campsite. I was fortunate to have the truck and trailer with me as I had hauled my KLR over for a friend to use. Thought things would dry out overnight and the bike might crank come Sat. morn, but no such luck. Too bad friend now I have to take the KLR.
Monday, I checked the hall sensor with the device built from the advrider hall of wisdom instructions, swapped the coil with the sweetieÔÇÖs 850R and swapped fuses and relays back and forth. I pulled the right side fuel injector and there was no fuel spray either. Fuel pump runs the normal 2 seconds when key is turned on. Side-stand switch has been eliminated sometime ago. The kill switch seems to work okay (kills fuel pump and RID display.) I have chased wires for broken connections.
Tuesday I began disconnection all of the wire connectors for cleaning and a good damp of silicone grease. When I pulled the electrical connector from the right side TB, a good amount of water spilled from the connections. Viola, I thought I had found the problem. I used compressed air to dry both plugs and coated with silicone grease. Fuel tank back on for 4th time and give it the old college try. No spark, no fuel spray.
I think the water in the connector is the culprit, but I donÔÇÖt know what it could have taken out. Just donÔÇÖt want to think about the Motronic unit being **** up.
The wiring diagram shows the fuel injector electrically connected to a timing valve. Does anyone know what this timing valve does and where is it located?
Any suggestions, critiques, prayers, or otherwise welcome.
Gary
Gary
