Lock Cylinder
tonyt0906
A buddy of mine is selling me his 49L top box, I have a 28L. Can I simply swap out the lock cylinder, or does the 49L case take a different one? TIA
Might want to take a look at the bottom of the page in the similar threads panel.
Good luck.
It works the same way on all the cases. I just bent a paper clip into that basic right angle and taped it to the end of a long screwdriver. Put the key in and turn it just slightly to take up tension and when you hit the spot with the clip it just pulls out.
