Does carb cleaner have any effect?
You could try some polishing cremes like Simichrome or Blue Magic Metal Polish Creme. Beyond that, it might need something like vapor blasting to get the shine back.
I messed up and left a CV carb in the ultrasonic over night. Now the carb body is a dark gray color. Any way to clean it up?
TIA.
Another question; there's a lot of chatter on the web about using Simple Green or Dawn soap and water to clean CV carbs, but I saw very little advice about what ratio of Simple Green or Dawn to use; a few drops? Half a bottle?
I used about four tablespoons of Dawn in a three quart ultrasonic tank, ran it for 4-5 30 minute cycles, and it made a soapy solution and cleaned the carb pretty well. The solution turned black on the first couple of cycles, anyway. My mistake was leaving the carb in the tank overnight.
I'm blaming the beer.
... followed by a thorough hot water rinse. .. the overnight soak has induced a chemical reaction with the metal.
Good luck, and I agree that the beer had a huge hand in this!
DeVern
