Recently after my last trip (and only trip this summer) a few weeks ago as I was unpacking, I managed to walk against a mirror on my K100. It bounced across the garage floor, cracking the mirror in many directions, without any of the many pieces falling off the backing. Clear library tape has worked for a few weeks ensuring the many pieces stay in place.
What is the best way (without cutting myself or destroying the mirror housing) to remove the mirror's ball from the socket inside the mirror housing in order to replace the actual mirror?
If successful, I will then use the same technique to remove the glass from a salvaged mirror to replace the glass on my housing.
All suggestions would be appreciated.
Thanks!
Thanks!
