Results 1 to 7 of 7
Thread: K1300S 2014 BMW-AF-XIED installation
    Greetings all,
    Has anyone tried to install one of these on a K bike. I知 preparing to do so and could use a little advice on where to located the connections for the O2 sensor. Do I need to remove the fuel tank to access it? Any feedback or pictures would be appreciated.
    Cheers!
    Registered User cjcs's Avatar
    Nov 2009
    South Orange Co. Ca.
    Quote Originally Posted by kbikecanuck View Post
    Greetings all,
    Cheers!
    I recently installed one on a 13GT
    While not the same as your S model the 02 sensor part numbers are the same so they may be similar as far as the electrical goes
    The 02 sensor connector plug is between the oil tank and the frame on the right side
    I used a 90degree pick to unlock and pull the connector apart
    didn't have to pull any panels off
    I zip tied the AF-XIED box to the rear lights wiring harness
    A fairly easy installation
    Carl S.
    BMWMOA #11500
    Thank you Carl S. I probably removed more panels than necessary but the installation was pretty slick. It has really smoothed out the bike. Took a bit of a hit on fuel economy but the gain in drivability and performance are worth it. Thank you again for your feedback.
    Cheers,
    Ken
    Left Coast Rider
    Cheers,
    Ken
    Were you suffering the dreaded engine dieing at idle issue? If yes, did this mod solve the problem?
    Nov 2009
    Engine stalling was the main reason I installed the AF-XIED. Did it take care of the problem?
    Its helped some but didn't completely take care of the issue.
    It depends on her mood that particular day:
    What the AF-XIED did take care of was the hesitation at freeway speeds.
    Not that she was a slouch to begin with.
    The XF-XIED also took care of the fuel economy.
    A noticeable improvement in engine performance.
    Disappointing that it didn't take care of the stalling issue.
    Carl S.
    BMWMOA #11500
    Left Coast Rider
    Quote Originally Posted by cjcs View Post
    Oh c'mon, we both know the K1300 is a slug.
    Thanks for the response.
    May 2015
    Oregon
    Greetings all,
    Cheers!
    I went even further down the rabbit hole and had the gas tank out looking at the air fuel probe on the intake...that's a temp sensor! Arg! My "never read the instructions first!" rule is officially deleted!
    Bottom line is the AF-XIED did help my 2009 GT mid-range "hiccup". The green-yellow light will tell you if you need to rich/lean the mix.
  1. 2014 K1300S Exhaust Bracket
    By 180354 in forum Wedge K-bikes
    Last Post: 05-08-2015, 02:28 AM
  2. 2014 RTW HID Headlight Installation
    By 80092 in forum Wetheads
    Last Post: 03-14-2015, 10:57 AM
  3. Want to buy a 30th anniversary 2014 K1300S, but!
    By Rangeron in forum Motorrad
    Last Post: 07-14-2014, 04:24 PM
  4. installation of amp on K1300S
    By P944T in forum Gear
    Last Post: 02-25-2012, 01:56 PM
