Welcome, Guest! We hope you enjoy the excellent technical knowledge, event information and discussions that the BMW MOA forum provides. Some forum content will be hidden from you if you remain logged out. If you want to view all content, please click the 'Log in' button above and enter your BMW MOA username and password.
Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
I had the rear rubber line fail on my 2000 RT in my garage shortly after I got it last year. Had my son holding down the brake pedal while I was torquing down the rear wheel lug nuts. I've got stainless Speiglers on the bike now!
I discovered a leaking fork seal on my '03 R1150RT and remembered reading this thread. Over the weekend I replaced the seal from the top. I removed the left side tupperware and this gave me much more room to work, I didn't struggle with it nearly as much as Chris Harris did in his video. The extra 10 minutes to remove and replace the tupperware was probably less than I would have spent trying to work around it.
Another thing I did that I think helped: I opened the vent valve in the top of the fork tube before pulling the tube out of the slider, and tightened it back down after re-inserting the tube. No struggling against air pressure.
