this might be a goofy question, but, I just bought a 2019 r1250rt and was wondering if you have to keep the bike running to clean the inside of the windshield , since it lowers when the bike is shut off ? thanks for any input
Have you consider just leaving it dirty. That has been working well for me
Well, I do commute to work daily, and I have to go over a mountain range which is typically getting rain...so, I sortta have an excuse.
And what mountain range might that be. From your Profile I can't tell if that is the Himalayas, the Alps, the Rockies, the Smokies, or something else?
Or, please fill out some info in a sig line or your profile.
For most of my windscreen cleaning I just do it with the ignition on. Not much drain on the battery, especially if it is done just before I ride which means the battery will be charging.this might be a goofy question, but, I just bought a 2019 r1250rt and was wondering if you have to keep the bike running to clean the inside of the windshield , since it lowers when the bike is shut off ? thanks for any input
The black crud is typically brake dust, sometimes with a little road grim added for good measure.... What do you use to clean the rim of your wheels. They built a black crud on mine that is hard to take off. I been using Windex lately--even that don't clean the hardcore black crud
