gsaddict
Pepperfool
Provided that is - you have 120vac......which the OP does not have access to128CEC1 model BatteryMinder - does it all
The OP seems to be MIA. Maybe he could tell us if he has access to sunlight. We know he does not have access to 120V outlet.
For my money the best answer is a high amp hour RV battery in parallel with the bike battery. Absent the wisdom of the electrical engineer guru types I invited in post # 7 I predict 3 months of no problems. Then charge the RV battery and repeat.
Hi Paul,
If you can accept a 10% drawdown of the big battery, and there are no added parasitic drains other than an Oilhead’s usual 2.5 mIlliamperes, then it should be good for half a year. That doesn’t take into account the self-discharge rate of the big battery though, which could be significant.
