rangerreece
RangerReece
Thanks for the advice. I will try to have an intelligent conversation with the service tech at Pensacola, get it done while it’s under warranty.
Whoa there, pilgrim, depending on how much Reese trusts his local dealer, check the easy stuff first!
Draining battery could also be the muffler bearings or maybe even a bad timing chain! To be on the safe side I'd recommend a complete overhaul of the engine and a fresh coat of paint.
I always find it unnerving that car fans continue to run after the engine is shut off. Probably because on the last car I owned, the fan was driven by a fan belt off the crankshaft and not an electric motor. It also disconcerts me when the headlights stay on after the ignition is shut off. With rental cars, I always have to stand there and wait to make sure they go off. I guess that makes me a geezer.
The coolant would circulate slowly due to convection (density differences), but without actual measurements of flow and cooling rates it would be hard to know whether that would make it worth running the fan. I would bet that the BMW engineers have considered this issue and rendered their professional opinion.
Ken
