I am troubleshooting a recent symptom where the engine will die without warning.
When this happens it has been with fully warmed engine ridden for at least an hour, in first gear just beginning to move off of a stop. It has not done it at highway speeds.
In this state the start button is inop and the only way to restart it is to recycle the key in the ignition i.e. switch ignition off, then back on and it will start right away.
There is no change in the instrument panel display when this happens.
To troubleshoot, I have bypassed the kickstand safety switch.
Tightened battery terminals.
Wiggling the key in the ignition or kill switch has no effect.
There is no EWS display.
This does not act like a faulty FPC. I have had that happen and the current symptom does not behave like fuel starvation.
This symptom is as though the kill switch has been moved to stop.
Ideas?
Regards
Kim
Ideas?
Regards
Kim
