History of events leading up to the run away engine.
1) Left low beam is burnt out so I am going to replace both bulbs. Left side done in less than 5 minutes.
2) Right side no matter how I twisted or positioned my arm I could not get the bulb in place so removed the small front side panel. Could see better but still could not get my hand in there.
3) Looked at the cruise control box and thought that by moving it off of its mounting bracket I could possible get my hand up in there. I disconnected the electrical connector but did NOT remove the throttle cable there was enough slack that it easily allowed the control box to slide out of the way. Still couldn't get the bulb in place.
4) Wife came home and with er smaller hands she was able to get the bulb in place and got the spring clips hooked.
5) Reinstalled the cruise control box and started the bike to confirm the lights work. Now the bike wants to run at 7,000 + RPM.
If I roll back on the throttle grip it will idle down & with the engine off the throttle seems to snap home.
I have removed the right side panel and observed the right side throttle body butter fly. With engine off that cable has free play in it.
The throttle also has some freeplay which would indicate slack in the cables. I.e feels normal.
I currently have the battery disconnected thinking possibly by disconnecting the cruise it triggered some fault.
Any other ideas?
TIA
Any other ideas?
TIA
