While doing a short ride today I used my turn signals for about 15 minutes then they stopped working (both sides). My flashers and clock also stopped working. All other electrical items work fine I.e. headlight, brakelight, starter, etc. Suspecting a blown fuse I checked these at the fuse block, all are good. Next item is the turn signal/hazard signal relay but this doesn't explain the clock not working. Looking at the wiring diagram the clock does not appear to be in the signal circuit.
The only assignable cause I've been able to come up is I washed the bike yesterday and am thinking water got into a connector. But why would the signals work after the wash and then today for 15 minutes?
Any ideas from the group are much appreciated.
