I recently purchased a 2004 R1150rt with 13k on it. I see a lot of discussion about the final drive failure and wonder if there is anything specifically to watch for or be proactive about. My old K1100lt never had an issue, period. It's got me a little nervous.
If they are sensitive to preload adjustment, any tips on getting it right.
Perhaps a bit off topic, but I have a related question...
Ride an '04 R1100S, with the standard suspension. Many other S riders recommend installing a GS style Paralever link to increase the rear ride height and quicken the steering a bit. I've noticed that bikes so modified have a less acute angle between the paralever and FD housing.
Just curious if that "straighter" angle might help reduce some of the strain on the pinion bearing and seal? Seems to me that might help a smidge...
Thanks for any feedback offered!
Cheers!
PS. And yes, my pinion seal is leaking!
Change the oil frequently - not because it needs new lube but because you can then find any sign of debris in the oil. That is the best early warning. You will find signs of debris long before you can detect movement wiggling the wheel.
Wiggling the wheel is your second line of defense.
If you are truly heading off to see the world, or absolutely don't want your two week vacation jeopardized then take it off, send it to Tom Cutter and have him check it and set it up perfectly. Then stop worrying about ti.
Paul G has frequently stated that frequent FD/trans fluid changes are at 6K intervals, same as engine oil.How often would you call frequently?
This video shows one way to do it, it's 38 min ->
http://www.bmwlt.com/uploads/lt_final_drive_rebuild.wmv
Ignore the horse in the first few seconds
My 2000 LT has 125,000 miles on the pivot bearings & my 2004 LT has over 190,000 miles on the pivot bearings. I clean & repack them every year. The out side wears more than the inside so I swap the races every time I repack them. I also buff the races with white rouge buffing compound in both directions on a buffing wheel.pivot bearings usually show up as play at 3 & 9, whille FD issues are more commonly found at 12 & 6 play.
Pivot bearings, unless periodically adjusted (easy DIY), typically die somewhere north of 20K (rare to go beyond 50K, but that is about the outside end of life).
FDs are less predictable. Mine has 82K on it, and have only had a seal go bad on my FD. And 3 sets of pivot bearings. Now i have the bushings.
Just experienced FD issues on my 08 K12 GT with 27000 miles. This video is excellent. Thanks very much for posting.
