Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Is the spring at the bottom of the fuel qty sender tube supposed to be compressed at the bottom of the tank? Mine is and fuel quantity on the RID shows one bar all the time...full or empty.
Are you certain that the cover is correctly installed so that the float can move freely? If the cover is twisted with respect to the correct position, the float arm will get bent, stuck or otherwise damaged and the fuel gage does not function properly.
Also, you can check the function by connecting the proper terminals of the plug. Careful, sparks can ignite fuel and fuel vapors...
Should the spring moved freely inside the tube? Perhaps my float is cocked and stuck. I have the tank off right now w no fuel in it so I will check for correct installation. Thanks.
