Wal-Mart has 15w50 Mobile1, $21 for a 5 gallon container
I used to drain the $$$BMW oil out of my K and top off my oil guzzling 302 '71 Bronco with it. Now I'm tempted to use the Mobil One I drain out of my VW 1.8t and use it in the bike. My theory that as the motor gets older it gets less particular about the oil, so long as it has oil.
Some oil is better than no oil, good oil is better than bad oil, and new oil is better than old oil.
Castrol or BMW Dino Motorcycle oil in the engines, automobile oil does not have enough moly and zinc content anymore for modern motorcycle engines.
When you have a motorcycle with a dry clutch, how does it make a difference? When you look at pistons, valves, bearings and other moving internal parts, you can't tell what kind of engine they are from. Besides, most of the changes to automotive oil are in the lighter "fuel saving" weights we don't use in motorcycles.
This reminds me of the dire predictions I heard when lead was eliminated from gasoline. Engines were predicted to wear out faster and give a lot of problems because lead was no longer going to be used. The results (once "some" manufacturers fixed their valve recession problem that most other manufacturers didn't seem to have) resulted in longer engine, plug life and exhaust system life.
Engine oil in the engine, gear oil in transmission and final drive, fork oil in the forks
...a problem with any motorcycle or auto engine that was caused by using a specific type of oil.
...change the oil and filter at recommended intervals...Gizmo
...156,000 miles and never had an oil change...ClassicVW
My 94 R1100RS has now passed 151,000 miles on it, almost all using Mobil 1 15W50 synthetic oil (my choice). I did at one time use Rotella-T Full Synthetic 10W-40, but was concerned about the 40w versus 50w rating in hot temps.
I just changed the oil recently, well about 1500 miles ago, and used Mobil 1 15W50 SM rated oil. I see above the reference to using SG service rated oil. So I went to the Mobil 1 site and found this bit of info:
"Using an SM-Rated Oil When an SG-Rating is Recommended
Question:
I just purchased a '92 Corvette and after changing the oil to Mobil 1 Extended Performance I noticed on the hood that it recommends an oil with the API rating of SG. After looking at the empty container it does not have this rating. Is this safe for my vehicle?
-- Larry Morgan, Auburndale, FL
Answer:
API ratings are backward compatible to previous generation ratings. This means that an API SM quality oil, which is the latest API rating, is recommended where API SL, SJ, SH, SG were originally required."
Granted, that's in a GM car engine with roller followers. API ratings may be backwards compatible, but is there still the issue with the additives? The label on the current Mobil 1 15W50 bottle says it contains anti-wear additives.
Thanks Paul for that detailed and specific response. After reading that, and doing more online research I see that I need to rethink what I put in my bike, especially since I plan to ride this bike at least to 200,000 miles. Especially given that most of the rotating parts in the Oilhead rely totally on that thin film of oil between the moving and non-moving parts.
Most of the miles on my RS have been lubricated on Mobil 1. But I'm guessing the the 20W50 Mobil 1 I recall from years ago is far different than the 15W50 Mobil 1 of today. Hopefully, those many years of running oils rich with ZDDP have protected the engine up to now with the non-equivalent oils of today. So I'm going back to the SG specific rated oils. Like the similar load ratings of final drive oil being as important if not more so than the viscosity rating. Can I apply the SG rating of a motor oil as actually more important than the viscosity rating itself?
If so, I may better off, cost wise, and engine protection wise, using Shell Rotella T synthetic 10W40 versus Mobil 1 synthetic 15W50. 10W versus 15W only applies in cold temps, and 10W will actually flow better than 15W. So long as the 40W high temp rating is sufficient in place of the 50W rating, given the better ZDDP protection of the 10W40 Shell oil.
It's the 21st century--why would anyone use anything but synthetic?
Even Castrol thinks you need to have hair like and dress like somebody from the 1970s to associate with their dino oil.
