M
masonke
Just noticed this tonight when I pulled into the garage tonight. The high beam indicator light was on no matter what position of the high beam switch. Looking, I discovered that both the high & low beam lights were out, but the parking light was on. I shut down the bike, waited, turned the bike on, same symptoms.
The fog lights work, so do all the other lights, just the high and low out with the high indicator on.
Looked through all Clymers, Haynes & the ops manuals and I cannot find any fusing for these lamps. The only controls seem to be the high beam switch and the Load Relief Relay. Since everything else works and the wiring diagram shows other devices off the relay, that doesnt seem to be the problem and the high beam switch doesnt control the low, so that doesnt seem to be in the path.
Any ideas or areas to check?
Kevin
Kevin
