kentuvman
Greetings,
I only have the Haynes book so far and don't see what's holding the gas tank from coming off - same for the seat. Someone drilled a hole to open the seat - obviously did not have the key - where is good resource for new locks & keys for forks, ignition, tank and seat?
Pulling tranny - it will need an o'haul. I read removing the swingarm is easiest way to remove it. Isn't there a special tool or socket I need to purchase to get into the swing arm hole to access the socket?
Is dual plugging a good suggestion for this bike?
Thanks much!
Ken in MN
Thanks much!
Ken in MN
