G
grumpyone
The fairing on the RT 100 we just got has boots I assume the RS and others do also. They are rubber boots (cups) the forks go through on each side that keep out the water and dirt. These actually do any good or are they needed at all????
Ours are old and cracked and handle bars turn with binding because of them when sitting still and we wonder if they arent haveing an ill effect on handling as it does not handle as well as the R 80 with out a fairing on it.???
Could be our fork and fork oil causing the problem but the boots seem to be screaming were making a problem here???
Jim and Esther
Jim and Esther
