Anybody else have an issue with the sidecases not locking on the bike? Both of my side cases are being temperamental about locking down. A friend's 2015 RT has the same problem.
If you're referring to the locks, a few drops of TriFlow worked into the mechanisms may help. That's what I did, and have been gentle when locking/unlocking ever since on my 2016 RT. YMMV.
+1 what ExGMan said.
Could you elaborate on this? Right into the lock where the key goes? Or taking the bags apart to get to the mechanism? My top box is a little harder than the panniers to open the latch when pushing the button.
The lock where the key goes. TriFlow helps all kinds of sticky locks, it doesn’t take much, a drop or two is generally enough.
My experience with my 2016 RT is that the cases have to be totally seated before I can latch them to the bike. Oddly enough BMW uses the same locking and mounting that Yamaha uses on their FJR, and was the same way on that bike also. Like anything you do with BMW , patience and detail matters the most.
