"SAFETY WARNING: Maintain recommended pressure and follow owner's manual. Only specially trained person should mount tire. To avoid fatal explosion, never exceed 40 psi to seat bead on a clean, lubricated, undamaged rim. Underinflation/overloading can cause sudden failure. Inspect regularly for damage. It is not recommended the repair of the motorcycle tires. REPLACEMENT TIRES MUST ALWAYS HAVE A LOAD INDEX AND SPEED RATING EQUAL TO OR GREATER THAN THOSE FITTED AS ORIGINAL EQUIPMENT."
I guess that about does it for CYA!!
See, that’s a lengthy warning to type out!
They should add ambient temperature inflation concerns
FTFYAnd a tort system that permits their frivolous cases to glean significant pay outs and birthdays wishes of good health!
And a tort system that permits their frivolous cases to glean significant pay outs.
After a lifetime - 40 years - in legal, I am no longer surprised by the utter stupidity of many of my fellow Americans.
I think the bigger problem are the companies that figure it's less expensive to settle before going to court. IMO, this encourages some to sue, then take whatever the settlement is since it's better than nothing.
