Take it to the dealer and have them check the microswitch on the clutch lever. You should not have to fully disengage clutch to trip cruise control off.
Best,
DeVern
I'm guessing you didn't fully disingage the clutch all the way
Check page 72 of the manual. Unless I’m reading incorrectly states clutch must be pulled in for 1.5 seconds to deactivate the cruise control.On prior years a mere fraction of a tug on clutch lever would disengage cruise.
That's not good news. I like using the clutch to disengage without flashing the brake light.
Is this happening on a bike with Adaptive Cruise Control? I remember now that Adaptive Cruise Control does not disengage with gear changes, so the 1.5 second delay could be necessary. Is there also a delay when using Dynamic (fixed speed) Cruise mode?
I’m just assuming here the reason but changing gears up or down with the cruise control active does not disengage the cruise control setting as in some previous models. On my 2016 RS if I shift the cruise control turns off. This is not the case on the 2022 RT. Likely something to do with the throttle blimp during gear changes which must deactivate the clutch even momentarily.Must be a reason for that? Wonder what it is?
Roll the throttle forward to disengage the CC/ACC without the brake/clutch.
Take note, you have to actually force the throttle past the idle/close position. Takes a little bit of pressure.
It does work, but to me (at least) it seemed strange at first. I got used to it.
The manual states "close the throttle by turning the grip past the idle position".
Rock on.
OP here...I do not have adaptive cruise.
Roll the throttle forward to disengage the CC/ACC without the brake/clutch..
