cam_on_van_isle
Member
Hello,
My OEM heated grips are only working on low.
I am getting around 6 ohms on both pairs of brown/black wires under the tank.
I assume since the low and high circuits use the same wiring, the fault must be the switch...?
Also, I have heard the switch is serviceable, at least can be taken apart and cleaned, is that true?
Many Thanks for your time,
Cam
Cam
