stooie
Member
First of all, a thousand apologies to all of you. This topic must have been covered hundreds of times in previous threads. Alas, I was 100% successful in absolutely failing to find anything using the "search" and "advanced search" tools on this forum. I'm sure it's operator error.
Does the engine oil drain plug require a 10mm Allen or a T55 Torx? It looks like either would fit. To my eyeball, the Allen fits better and that's what I used this time. Going forward I'd like to be sure I'm using the correct tool.
What say you all?
What say you all?
