so, I replaced my brake lines the other day. putting the bike back together its not firing on the right (brake) side cylinder.
I checked the usual suspect throttle cable not seated, no luck.
checked to see if it has spark... spark plug looks nasty but it is sparking. I replaced it as well.
swapped the coils, same effect left side ok right side no good.
im wondering if the 2 fuel lines coming out of the tank are one per cylinder? there are some quick disconnects there and it seems like the simplest thing is if one of them is not working esp because it is something that changed during the job vs. mysterious failure of something else by coincidence. ( but I don't know for sure if this is how it works.)
any tips on other things to check and how to further test the fuel delivery most appreciated.
