R75/5 Leaking fork tube at fork brace
JB1973R75S5
Has anyone repaired a fork oil leak at fork brace bolts ?
Thread is stripped in fork tube.
Can not find M13 Helicoil kit.
Any suggestions?
Just looked at fische.
The stud is M8 x25.
I also see on the picture of the SS stud that the thread lengths are not the same on either side of the center non-threaded portion.
Probably why I stripped it in an attempt to have the same amount of thread showing through the nut when installed.
I think they make M8 heilicoils.
I still wonder if I will get a good seal when the helicoil is set. I suppose red Locktite will do the trick.
