F
From MARS
Gravity,
If there is oil where there is supposed to be oil, then somebody has put it in after the submersion. Hopefully, the engine, transmission, and FD were pickled within hours of having been submerged. On boats, this involved flushing the cylinders and oil pan with fresh water, turning over the engine (by hand if possible) with the injectors/spark plugs removed to force out as much water as possible, then coating the cylinders with something like Marvel Mystery Oil. All electrical parts were pulled, rebuilt/replaced, and the connections treated with Corrosion Block. The first oil/filter replacement was done after just turning the engine over with the cylinders open. New oil and filter would be put in, and the engine started. After 5 minutes of running at idle, the oil/filter would be changed again and again until there was no indication of water.
The killer is if water was left inside the engine, and it was allowed to sit.
Tom
Tom
