crazydrummerdude
advrider.com
Exhaust. It's a typical 4-stroke. Nothing fancy.
I'd do what Dennis said.. strap the centerstand forward so it won't collapse on you when you're lifting the rear, bump the transmission up into 5th, and rotate the rear wheel. (This is the same version of the procedure for valve clearance checking/adjusting. You watch the valves while you rotate the rear wheel (or the allen bolt) and wait for it to get to TDC, which you verify on the side of the flywheel "OT" in the little window on the left side of the engine.)
Maybe I dive into things, but as soon as I got the bike and changed out the fluids, I'd just hook it up to a battery charger and hit the starter button for a split second and see if it rotated anything... then proceed from there.
