If your bike has a tool kit with it, put it somewhere other than under the seat before you pack your stuff onto your bike. Y'know, somewere that if you need it, you don't have to un-pack your bike to reach it.
Check out Touring Tips. There's a ton of good info from fellow members.
http://www.bmwmoa.org/features/touringtips.htm
I always carry an extra set of cables, tire plug kit with an aircompressor, JB Weld quick set. It depends also where you travel. If you go off into the wilderness, tires, oil, and water etc may be a good idea.
What about the Co2 cartridges?
s
[*]And probably the most important piece of gear: The Anonymous Book
[/LIST]
They will fill your tire, but not to the proper pressure. There will be enough pressure for you to make it to the next gas station to get some air, but that's about it. I'm sure others will chime in. I've never used them, but I've heard from people who have.
Airheads come with a tire pump in it's own little special space under the seat. Don't need no stinkin' compressor. And what is wrong with having the tool kit where it belongs, under the seat? To get at it I only have to remove the right side pannier and open the seat. I don't put anything on the seat except my seat.
If it doesn't fit under the seat, in the saddle bags, in the fairing pockets or one of my pockets, then I definitely do not need it. I have traveled all over North
America that way. If you do it right, you can be away for months and not have to strap anything to the bike. But then I tend to be somewhat minimalistic.
