A
AdventureGoat
Is there any harm (other than the obvious additional financial burden) in changing the engine oil frequently. Say, every 2500 miles.
An acquaintance of mine didn't change the oil in his lawnmower for 15 years. It was still operable when he retired it last year.
Rinty
...PS - this is my last comment, because we are risking the dreaded oil thread here
Yes, there IS a harm that can befall your bike with too-frequent oil changes. It is commonly held that the greatest chance for wear occurs immediately after an oil change, when the engine is started and the oil filter and all oil passages need some time to fill.
Why? ............Is there underlying reason that you are considering more frequent oil changes?..............
..........Again, why?.......
And this potential damage can be largely alleviated by filling the filter with fresh oil prior to installation.
AdventureGoat,
The old 2,500 to 3,000 mile oil change interval made more sense "way back when" than now. Engines were built without oil filters up until sixties, for the most part. They also generally vented blow-by gasses out of the crankcase through simple breathers, rather than using intake vacuum to help draw them out. Frequent oil changes were required to keep them clean, (or at least less dirty). It did not have as much to do with the actual useful lubricating "life" of the oil as you might think.
AdventureGoat,
