charlesodle
How often should the drive shaft splines be lubricated? There in nothing in my owner's manual for maintenance of splines. What does BMW recommend?
We could only hope for a driveshaft with zirk fittings. Nice you have one I would assume a earlier model year?I lube the FD splines every 12,000 miles. I was pulling the driveshaft and lubing the output shaft splines every other winter. This also allows for checking the u-joints. Since I had my driveshaft rebuilt with zirks installed I will be pulling the driveshaft every winter to lube the u-joints, at a minimum.
I had thought someone had made mention that Ted Porter or someone was working on zirk fitted shafts for LC bikes?
I do agree I will do my second spline lube upper at 24K and 12K for the FD and keep that schedule. It is really just patience in doing it, and if your lucky you can time it with a brake job or a tire change.
I had thought at one time spline lube was a constant, and a listed (user mandated) maintenance, I just cant remember what years/series.
I have a 17 R12GSA. When I pulled the driveshaft last winter I found that both u-joints were showing early signs of pending failure. I talked to Ted Porter and he said he was expecting to get rebuildable driveshafts for the LC models. As winter became early spring there was evidently some issue with the production and Ted no longer would make a prediction about when he will get them. So, I sent my driveshaft to a machine shop in Green Bay, WI. They rebuilt the shaft and installed zerks (plugs actually; I put in the zerks). They charged $230 and shipping was $25 each way. Much cheaper than the $1256 BMW wanted; it may be more now. I just pulled the driveshaft again this month. It only had 4,000 miles on it, but I wanted to check it and lube it. I’m having a sidecar installed next month and wanted to do the job before the lift was no longer an option. So far everything is copacetic.
I just installed a replacement U-joint with a zerk that you can put a standard grease gun on. The grease gun fits thru the splined end of the driveshaft when you have lowered the FD for spline service.
Looking at the above YouTube video just a little bit, he only shows making a hole in 1 of the bearing cups. In the comments he answers a question saying that you need to do this access hole in all 4 cups to get grease to all 4, since the cross yoke is not cross drilled.
The U-joint I used has a cross drilled yoke so that the center zerk gets grease to all 4 cups at the same time.
Here is the part I used. https://www.driveshaftparts.com/index.php?route=product/product&product_id=862&search=gua2
This is the finished product. Kinda hard to see, but I got 4 stainless steel washers, turned them down to exactly 19mm to fit in the yoke bore, then TIG spot welded the 2 sides to ensure that the caps don't migrate out of the yoke.
The original installation has the bearing caps staked into position, so this is what I did instead of trying to weld on the bearing caps themselves.
