Anyname
Active member
I've always filled the final drive on my 86 R80 monoshock until the level reached the overflow hole. This past weekend I tried using the 350cc volume the manual recommends. That turned out to be way more than needed to reach the overflow hole. So what do you all think? Is the measured volume correct or should I stick with the overflow hole?
