Bike got wet under water for 2 days. (don't ask) Changed all fluids it starts runs good.
Fault codes: E11438 instrument panel: no CAN message status spring strut (from ESA)
E11436 KOMBI: no CAN message for vehicle access (from EWS)
CD9436 DME: CAN message (from electronic immobilizer) error
803EC1 GMS:under voltage
800FFD GM: under voltage
S 0332 No communication to the ESA.
Symptoms : Bike will start and runs fine.
Battery is fully charged at 12.8 volts engine not running.
engine running voltage is 14.4 measured at the battery and on the on board display.
there are no lights (head,tail,stop and turn) or horn.
nav will not turn on when attached to bike but works as should unattached.
radio and bluetooth work.
windshield will raise and lower using switch but will not park when ignition is switched off.
RDC shows — — on display.
When attaching battery there is a spark and the battery will be discharged the next morning. (seems to be getting worse)
warning lights that are on: ASC but may go off when ridden.
ON-board voltage critical ( yellow) even though the voltage is 14.4
Battery charge voltage insufficient(red) even though voltage is 14.4
Light failure (yellow) probably because of low voltage indication.
ESA fault
service icon
any thoughts?
ESA fault
service icon
any thoughts?
