b25bsaboy
Good evening,
Well it took five years from the time I started the strip down to getting the 76 R75/6 back on the road and I must say it has been an interesting journey. Before I get into my issue, I want to say that of all the machines (British) I've restored, this one is on top of the list for something that is beautiful to ride and handles like a dream. Once I figured out where the engine rpm sweet spot is, that is the range I try and ride at. This machine is smooth
The issue, or maybe this is not an issue, but when I shift gears whether shifting up or down the engagement is clunking and not smooth. Shifting into first get is smooth, and up to fourth gear it sounds and feels like its not engaging smoothly as it should. The clutch was adjusted as per specification between Clymer, Haynes and the BMW shop manual. Of course we have to mention our friend Chris ? who has a number of You Tube presentation both in pictures and colourful vocabulary.
What more can I do to get the shifting smoother than it is? Re adjust the clutch? Slow my throttle time down before engaging the clutch lever and then shift. Open to all suggestions.
Will try and find some pictures to post, and here are two.
