In the process of upgrading the pitiful stock horn on a 2014 R1200RT to a Denali Soundbomb mini from Twisted Throttle. Denali rates the Sfoundbomb mini @ 6 amps
Anyone know the amps draw on a 2014 R1200RT stock horn?
Stock Horn Nomenclature:
Clarton Horn 00.1163 70/388.1163 Made in Spain 12V 335Hz
Sympton: short bursts the Soundbomb mini works like a champ @ 113db, yet when I hold down the horn it goes from a consistent BEEP to intermittent bursts almost like Morse Code, eventually it just shuts down, then nothin'. After I turn the bike off, the horn works again, repeat. Sounds like the Canbus is shutting down the circuit because of a difference in draw.(?) I don't have a '911 to check, so I'm guessing, thus my question
I have confirmed through Twisted Throttle and Denali the horn is installed properly. I also used a "plug & play" custom wiring harness from twisted throttle.
Thanks in advance. . .
