An announcement has been put up on the forum to highlight some potential changes/issues this weekend with accessing the forum. The annoucement can be found at the top of any forum area...here's one location:
https://forums.bmwmoa.org/announcement.php?f=13
This is what the announcement says:
If you have any questions about how to ensure you can still access the forum later on in the weekend, post your question/concerns below. Or send a PM to me or any of the other moderators.
****** vBulletin requires that an application which coordinates username and passwords must be disabled beginning May 1. The vBulletin forum will still be active, however. If you logged in previously and used the "Remember Me" box, then you should see no issues on May 1...you should still be logged in. However, if you routinely log out of the forum and/or don't use the "Remember Me" box, you will need to go through the vBulletin "Forgot My Password" process and reenter your password. Once you've done this once, you should be OK the next time you come to the forum and are asked to log back in. To avoid having to do any of this, it is best to ensure that you checked the "Remember Box" when logging into the forum. If you are having difficulties and can't get into the forum, then you will have to contact the office early next week for help resetting your password. *******
