Hello,
I have a 1973 R75/5 LWB.
A few weeks ago a fuse blew and I have since narrowed down the problem to the front right turn signal cover.
I checked out the wires and also replaced the bulb for the turn signal. With the right signal cover left off, I turned the bike on, and the turn right turn signal worked fine and no fuse was blown. I turned off the bike, rescrewed in the cover. When I turned on the bike again, and tested the right turn signal, the fuse immediately blew again. I tried this a couple of times, all with the same results. Eventually, I noticed that if I did not tighten the cover screws all the way in, the fuse would not blow. There are no metal parts touching the housing/casing on the inside. Unfortunately, I need the screws tightened in order to keep the cover in place.
I am six month new to /5s and any information or advice would be greatly appreciated.
Thanks!
Percy
Thanks!
Percy
