I tried to dig in and see if I could figure out why my speedometer isn’t working. First issue is I cannot disconnect the cable from the speedometer the metal is spinning in the plastic housing. If I spin the end that goes into the transmission I can hear something moving in the speedometer but the needle doesn’t move should I bother trying to take this apart it appears I have to pry the bezel off to remove the plastic part from the metal housing . there seem to be an expensive Speedo‘s from India for about $30 but the cable comes straight out the back instead of an angle like the stock unit and the metal housing mounts differently. Advice? Has anyone tried to adopt one of those.
https://www.ebay.com/itm/Black-Dual...d-f2e3-4529-a8aa-f45b1b0d293b&redirect=mobile
