sailorlite
It seems the cheek pad sets for the Neotec aren't available yet - maybe 2-3 more weeks according to my dealer.
Just purchased a new Shoei Neotec. So far so good. I have been wearing the helmet around the house to give it a little break-in. So I will be outside riding my RT. First impression, I really like it. I have never had a Shoei before. Last Helmet was an Arai Quantum II. Head fit seems good so far with no hot spots. Check pads are thick. Will need to get used to the pressure on my face until the pads settle in. I am planning to install a Sena SMH10 on the helmet but have not seen or heard anyone else's install experience with the clamp style. Any advise would be great.
JL
JL
Zoomzoommo, thanks a lot for posting the pictures of your Neotec with the Sena. This gives me a great look to work with. Did you have any issue pushing the mount into the helmet between the outer shell and core lining? Looks like you didn't have any issue with the visor lever either. I may look into the Sena plate with the detached mic. It gives you a little more room to work plus I may be able to install the mic in between the check pad.
JL
Zoomzoommo,
Did you have to remove the chin cold weather guard from the front of the helmet or does it slide freely over the mic when you open/close the lid?
JL
+1 on the thanks for posting the photos. Looks like you used the clamp on the mount, right? Not the adhesive backed plate.
Looks good. I'll be ordering yet another mount I guess. Two Senas, 4 helmets, 2 heads. I'm very lucky that my wife's head is so similar to mine. We each have a primary helmet, I have a dual sport, and now my old Nolan if she wants to wear a modular instead of her Qwest.
I used to wear Shoei helmets. Headaches and a big red dot on my forehead. Is there any improvement on this issue with the Multitec. Wear the long oval Arai now but would like a flip front.
