Replacing Sight Glass Questions
mhallman
Member
I bought the Wunderlich replacement sight glass with the C-ring for my 1100 RS. I couldn't find the process for replacing the sight glass in my Clymer manual but watched a couple videos on removing the glass. From what I've seen, drill/punch through the plastic and gently try to pry it out with a screwdriver. Is this the best way to take it out? What are some of the things I could screw up and make things worse?
Also, is there a trick to reinstalling the new glass with the C-ring? Videos show to use a large socket to force the new glass in, but none of the videos had the glass with the ring. And again the most important question, what do I need to be sure to avoid when reinstalling?
Thanks in advance.
Similar to removing an oil seal.
I use a strip of hard wood of the appropriate size to pivot the screwdriver shaft against it. Acts as a fulcrum. And don't run the end of the screwdriver on the aluminum mating surface as you are pivoting it out.
See if information here helps-
There are other threads as well. Usually on a “seal” like that, I would drill in and use a self-tapping screw to provide a “handle” to carefully remove the seal.
Good Luck.
Good Luck.
Would a screw work or cause a new problem if it was a new SG that had a glass rather than a plastic window? 🤷‍♂️
To drill glass, you would need a bit capable of drilling glass.
Any of this type of work needs as Deadpool would say- “Maximum Effort”.
A glass sight glass would shatter in most removal cases. I am 99% sure it is plastic. Owners can use a soldering iron to melt the plastic sight glass. And the screw goes into the sight glass retainer, not the glass. Just checking in case you misunderstood OM
I just sold my 2003 R1150 GSA that I bought new 20 years ago. I used to carry a new sight glass, a new oil fill cap and O-rings for the quick disconnects in a small Nalgene jar in case of an emergency. I never needed them. LOL
The sight glasses were originally plastic and it was a simple matter to melt a hole on the clear plastic then use a screwdriver or brake spring tool to pluck out the sight glass. But the plastic got cloudy over time so a switch was made to glass, and the glass windows need to be left intact and extracted by the rim. As OM suggested above, a sheet metal screw inserted into the rim portion makes a great “handle” for pulling the sight glass. Just please don’t try drilling the glass unless you don’t mind fishing it out of the crankcase somehow. :oops:
best,
DeVern
The sight glass fits many different models and years. Your 1100RS does not have a channel to hold the clip that comes with the new sight glass. In your case, you throw it away. I think the 1200 bikes are the first that have the channel to fit the clip.
Thanks. Should have asked before I bought it - could have saved twenty bucks on a cheaper version.
As far as I know it's the original - I bought the bike about 6 years ago. I'm making the assumption it's plastic...
That's how I replaced them. I just drove a self tapping screw into the rubber outer edge and yanked it out with a pair of vice grips.
Just to follow up. I took the advice to use a soldering iron. The plastic melted easily and I carved out enough of the plastic to get a screwdriver in. I almost think I could have pulled it out with my fingernails - it came out in about 5 seconds (had good lubrication around the rubber :)). It was clearly ready to pop. Spent more time getting the new one to fit in.... Thanks for all the advice.
