That is absolutely true. They are packing more, thinner plates into small cases to increase battery amperage at the expense of durability. The typical VRLA (valve regulated lead acid) sealed battery failure today is not chemical depletion: it is a mechanical failure due to a fractured inter-cell or inter-plate connector.
Are you saying that the low capacity batteries could last longer because of thicker plates?
