ezwicky
Member
I asked this on the Airheads list but no reply yet, so I want to ask here as well:
On my '80 R100RS with Brembo rear disc brake, the lid of the fluid reservoir has terminals for low fluid warning, like the under-tank one for the front brakes, but the doughnut-shaped float does not move up and down like the front one does.
It is completely rigid, no play up or down. Fixed to a post that seems molded into the underside of the lid.
It's all plastic, nothing I can see to rust or freeze up, and the rest of the reservoir looks fine, the fluid was clear, no gunk in it.
Replacement reservoirs have a flat lid with no provision for low-fluid light, so even if mine is "bad", the replacement ones don't function either, so I'll stick with this one I guess.
But how does the fluid level open or close the switch? I took the terminals off, cleaned them up and tried to get a peek inside but the orifice that the screws go in is too small to see anything.
Thanks in advance,
Eric
Thanks in advance,
Eric
