n1hnr941
Just pulled my radiator fan on my 96 k11rs. The forward end of fan had been hitting hard against the radiator and has done some minor damage to the fins. Doesn't look like it went too deep. I caught it in time. The fan had been squeling and making a racket. Anyway my question is because I can't see how the fan is attached, how is the fan attached to the motor shaft. The end is all chewed up and I don't want to pull it apart until I get my replacement fan assembly. I am not sure if the fan has slipped on the shaft or that the whole motor and fan assembly has shifted forward. And I found a spacer under the fan bracket and I assume it suppose to be there and I am missing one, is there suppose to be one directly forward of the fan centerline? If there is that is where my problem is Thanks for the help in advance. Bob Hearn, biddeford Maine
