plehman
http://www.pbase.com/dwerbil/image/14562012
Odometer stopped working recently. I'd done the JB Weld procedure before and the gear on the main shaft seems to be solid. But the worm gear was not engaged against the main shaft when I opened it up. When I turn it against the worm gear I cannot move anything. Sure looks like it should be engaged. When I back the worm gear off things turn, but I don't see what drives the odometer.
Question: should the worm gear be engaged against the odometer main shaft as now shown in the photos?
thanks a lot.
thanks a lot.
